Cyclosiloxane peaks in blanks on GC/MS
Posted: Thu Aug 20, 2009 3:10 pm
This may be a stupid question I just wanted a clear explaination of what occurs when a polydimethylsiloxane column (HP-1, HP-5, DB-1 etc.) begins to break down or bleed. Typically I see evenly spaced peaks of cyclosiloxanes such as D6, D7, D8, etc eluting stepwise with equal resolution to neighboring peaks. I have always been told that this is due to column bleeding, although I have always seen this as raising baseline. It appears as if sections of polydimethyl siloxane stationary phase of different lengths are being stripped from the stationary phase and appearing as peaks. Using an MS detector each peak appears as a cyclo instead of a linear siloxane with the typical M-15 loss caused by EI. I assume others see this?[/img]
