bile acids
Posted: Tue Nov 30, 2004 9:22 pm
I have a need to analyze bile acids - cholic acid, deoxycholic acid, chenodeoxycholic acid in aqueous solution.
Problem number one is that these acids are only very slightly soluble in water unless at a pH of around 10 or so, pKa's are around 5. I have an RI and a UV detector, the low concentrations in neutral pH I don't think I am going to be able to detect.
We haven't designed the experiment yet, we may be able to run at high pH. If so, can someone suggest a column? Would a "ruggedized" silica column work ok or would I have better luck with a organic resin based column?
Supposing we cannot work up the experiment at high pH. I am thinking maybe I can dry down the supernatant from the experiment, dissolve in MeOH and run in reversed phase conditions.
Any thoughts? I know there are some sharp people on this board.
Mike
Mike
