Greater detector noise after switching columns and jet
Posted: Thu Aug 13, 2009 2:32 pm
I just switched columns on an HP5890, and also since the columns had a different ID I had to switch the jet as well.
I have always had very smooth peaks and baseline, but on my first run (blank) the noise was dramatic such that the baseline looked 3-5 times thicker due to signal fluctuation.
Could someone please help me troubleshoot this. I am about to try reconnecting the column to the detector making sure the measure is the proper distance. Any other suggestions? Is it possible I didn't put jet in right (eg. too tight/not tight enough)?
I thank everyone on this forum, as I have learned so much since I became a member.
