Agilent Chemstation GUI Display
Posted: Tue Aug 04, 2009 8:19 pm
by Eric Moore
Hi, all -
I just noticed something, and wondered if anyone knows what is happening.
I have an Agilent 1100 with a quaternary pump, running Chemstation 10.2 (I think).
When I set up initial conditions using three lines, and one of the lines is between 11 and 20%, the GUI displays the % value (for the 11 to 20% line only) in white instead of black.
Is this a warning regarding flow rate or mixing accuracy?
I searched the help section, but couldn't find anything out.
Thanks - I don't think I'm crazy, but maybe I am.
EM
Posted: Sun Aug 09, 2009 11:34 pm
by mbicking
Given the choice between you being crazy and the ChemStation being crazy ... you are going to win every time.
I no longer have this version around, but my guess is that it is a graphics driver problem. There is nothing in the software that I remember about this, and I know there is not automatic "warning."
Try updating your graphics driver or change the hardware acceleration settings and see if that helps. Of course, the first Windows solution you should always try is ... reboot!
:P
