Alternative to exit end fitting with integrated connector
Posted: Sat Apr 03, 2021 12:44 am
by akhst7
We recently purchased the Agilent High Performance Reliance Cartridge Guard-Columns and Zorbrax SB-C18 to replace the old Water's Resolve C18 column. My question is if it is possible to replace the exit end fitting with integrated column connector with male to male connectors
or this
. Or suggestions to any other alternative that makes a shorter coupling between a guard and C-18 column will be appreciated.
Re: Alternative to exit end fitting with integrated connector
Posted: Thu Apr 08, 2021 12:18 pm
by TylerSmith123
Hi akhst,
Firstly, I'm not familiar with Agilent systems and their columns and guard columns so please take some of this advice with a grain of salt. The first thing I would recommend is getting your images to load properly on the forum (at least I cannot see them). This would help me understand the guard column and accessories. The guard columns my lab purchases from Phenomenex comes with a zero-dead volume fitting that goes between the guard column and the actual column, and I think that this is similar to your integrated connector but I'm not sure without the images or part numbers. This coupling is extremely short and any change in retention would be due to the volume within the cartridge rather than this tiny connector. However, this could be completely different on the Agilent systems. As for removing the end-fittings themselves, this can be a tricky and you might end up completely disturbing the bed mass and causing a void. It seems like you want to have a zero dead-volume connection between column and guard-- making a void would basically nullify any of that work. But that's not to say that depending on the column and person it cannot be done. First I would try and upload the images (unless it's just me) through the recommendation stickied on the front page of this board.
