please,what do you can tell me about this
Posted: Thu Jul 30, 2009 11:54 pm
i use normal phase to determine a compound at 210 nm.I used heptane and IPA IN THE MOBILE PHASE,And i used a CN column.
My peak shows a great band of absortion at 218 nm.
in a past test done,the peak was elute verwell at 210 nm,but in that moment i used hexane and ethanol in my mobile phase and a L3 column,i.e (Si column).
any can tell me if this changes in the system do the change in the maximum of absortion of my peak?
Why happened that?
Can i do my test at 218 nm?
my employed method result invalid at 218 nm.?
Many thanks to all for your comments.
best regards
Paul.
Why happened that?
best regards
Paul.
