repairing Agilent G1379B degasser
Posted: Thu Jul 30, 2009 2:37 pm
I've been using an Agilent G1379B degasser in my lab for about 1.5 years now. We've begun to see an accumulation of a salty deposit around the vacuum exhaust line on the front of the solvent drip tray. Since we have never used any salts in our mobile phases, I'm pretty sure that this crusty accumulation is coming from the vacuum pump. Furthermore, upon disassembly of the degasser, I found traces of liquid in the vacuum exhaust line. The solid is also tinged with green (copper?). The degasser has not yet generated any error codes.
All of this leads me to believe that I have a small membrane leak, that solvent has been aspirated into the vacuum pump, and then the solvent (with 0.1% formic acid) is carrying away bits of the vacuum pump as it exits thru the waste line.
My questions are:
My questions are:
- 1. Has anyone else encountered this failure mode?
2. Any suggestions as to how I figure out which of my 2 vacuum chambers has failed?
