On-Line Preconcentration of Sample in Chromatography??
Posted: Wed Jul 22, 2009 4:04 pm
by rick1112
hi
I would like to know about the methods or strategy for “On-Line Preconcentration of Sample in liquid Chromatographyâ€
Posted: Wed Jul 22, 2009 8:03 pm
by tom jupille
Simple: if your diluent (what the sample is dissolved in) is much weaker than your mobile phase, you can inject a very large volume and the analyte molecules will "stack up" on the head of the column or guard cartridge.
Posted: Thu Jul 23, 2009 6:05 am
by rick1112
thanks tom
we have been doing the same for some of our samples, so in some samples we end up making large multiple injection ( the only problem i see in this is that there is always a question on sample diffusion in sample loop etc...) i reason for my post was i have seen some articles regarding On-Line Preconcentration of Sample in capillary electrophoresis and in some ion exchnage i was wondering if there exist any method or strategy for protein samples for liquid chromatography (mainly for IEC and RP )???
Posted: Thu Jul 23, 2009 2:55 pm
by HAZMAT
Here are links to 3 application notes that cover this subject. These notes provide a great review of both online preconcentration and the complementary technique for online sample-cleanup.
The plumbing diagrams for 6port and 10port injection valves are also included for both techniques.
http://www.optimizetech.com/opti-shop/lit/an101.pdf
http://www.optimizetech.com/opti-shop/lit/an102.pdf
http://www.optimizetech.com/opti-shop/lit/an103.pdf
Posted: Thu Jul 23, 2009 9:03 pm
by tom jupille
It's the same principle in all of those cases. If your protein is dissolved in a weak solvent (aqueous buffer for RP; low ionic strength or a pH on the "wrong" side of the pI for IEX) *and* if the injection volume is large enough that relatively little mixing with the mobile phase occurs, then the protein will accumulate on the head of the column and you will get a reconcentration.
How large a volume is usable (or required) depends on the difference in eluant strength between the diluant and the mobile phase and on the mixing characteristics of your system, so it's difficult/impossible to generalize; you have to experiment and see what happens.
