how to get sharper peak shape?
Posted: Tue Jul 21, 2009 2:05 am
by moonchips
I am trying to develop a short assay for solubility screening.
I used YMC pro C18 column. 150x4.6x5 column.
what can i change to get sharper peak shape?
Posted: Tue Jul 21, 2009 1:29 pm
by skunked_once
The easiest way is to slow down the chart speed on the integrator :lol:
Please post more information. We can't help without knowing the details of your method. We could suggest changes in flow rate, mobile phase, or the column.
Posted: Tue Jul 21, 2009 7:05 pm
by moonchips
I need general suggestion of making peaks sharp:
high temperature, faster flow, initiall hold etc?
is isocratic usually sharper than gradient or broader than gradient?
will a sharper gradient result in sharper peaks or a shallowe gradient result in sharper peaks?
My main peak does not pass the peak purity test. Should I alway care about peak purity for the main API peak?
Posted: Wed Jul 22, 2009 2:38 pm
by mbulentcakar
Faster flows and gradients will work for sharper peaks. Also higher temperatures, and smaller particle diameter (larger plate count without peak broadening effect) will help.
Hope this helps.
Bulent
