Any tricks to reduce needle plug?
Posted: Wed Jul 15, 2009 10:08 am
Dear all,
I am using manual injection needle (Hamilton, point style 2, needle guage 26 or 22) to inject samples.
Almost everytime I insert the needle through the septum, the needle will "tear off" a tiny bit of septum, causing the plugging of the needle.
Is there any tricks to avoid this problem? (Am I over-tighten the septum retainer nut to cause the above problem?)
Thanks in advance.
Thanks in advance.
