Should there be only 1 quantifier ion?
Posted: Fri Feb 05, 2021 7:35 am
When reading about quantitative analysis via MS I see that we need to:
1. Choose a quantifier ion
2. And check qualifier ions and their ratios: to see if it's really the analyte of interest
I was wondering - is it important to use only 1 ion (I assume it's almost always the base peak mass) for quantification? How acceptable is it to include additional isotopes and/or adducts when calculating peak area for quantification?
My understanding is the more masses we include - the more unrelated ions we risk to capture. But at the same time the smaller the peak area (because we chose only 1 ion) - the more impact different kinds of noise have, so the uncertainty is higher.
