Repairing gradient mixer in Waters 600 system
Posted: Mon Jul 06, 2009 11:22 pm
First, I wanted to say that I'm reading this forum for a couple of years already but did not register until really stuck and need some help.
It is a typical 4-channel Waters 600 mixer with solenoid valves. When I run the tests, channels A and D are more or less OK (still gradient shape is not perfect), channel B is somewhat malfunctioning, and channel C is completely failing to work in combination with A but somewhat works in combination with B. A+D and B+D work rather well. I called the tech support and they recommended to replace the whole mixer which is very expensive. We are on a rather tight budget at the moment and cannot really afford that. The 600 machine is about 10 years old and is not in the best condition.
We however have an older 600 system and the solenoids, mixer, and connectors there look the same and are also IEEE-compatible even though they are linked with green wires instead of red on the newer system. That older machine is not used at all and I can salvage whatever parts I need from it (already replaced the plungers on the newer pump heads). I was thinking whether it is reasonable to try and replace one-by-one the defective solenoids. It is a lot of work, so it would be very nice if somebody had some experience with mixer rebuilding or repairs or may be there is something else wrong like defective central block or some tubing. While tubings do not visibly leak and the system had been washed through with about 3 liters of methanol and isopropanol for the past month, I'm not so sure about actual valves.
I searched the fora but could not find anything at all.
Any advice is highly appreciated, please help!
