Column length effect on peak resolution
Posted: Thu Jan 28, 2021 1:12 pm
I was reading Snyder's Gradient HPLC book. It says that keeping all conditions the same, the shorter the column length the better separated the peaks(higher resolution). I believe this is correct. However, I am not able to overcome the feeling that if I keep on shortening the column, 50 mm, 20 mm, 10 mm, 1mm...the two peaks were separated by 2 min, 4 min, 6 min, 10 min, 20 min...(all values are not true buy only used to illustrate the concept) Something must be wrong.
Please help to rationalize! I am sure someone already covered this. Please help with reference. Thanks.
