Headspace Syringe Maintenance
Posted: Mon Jan 04, 2021 4:45 pm
I am wondering if anyone has any advice on best practices for cleaning and maintaining a headspace syringe.
The syringes and needles clog and eventually jam if I do not clean them after each use. I run on average 30 headspace samples per run (a few times a week). There is only 3 ml of brine and one gram of sample in each 20 ml headspace vial, but for some reason traces of salt make their way into the needle from the brine.
I was rinsing the syringes by drawing water in and out with the needle attached. I ruined the adhesive of one of them because of the excessive force applied to the conjunction. I had better luck once I removed the needle and began to clean the syringes by drawing water in and out of them through the wider opening (no needle attached).
Has anyone had similar experience? I think both of the syringes that I have been rinsing this way are losing accuracy. I just bought a sonicator in hopes that it will provide a gentler means of cleaning the headspace syringes.
I appreciate your feedback.
