Asking about extraction...
Posted: Fri Jun 26, 2009 3:12 am
by brightsun
Hi everybody, i have one question about extraction...
I'm running PAHs, i use EPA Method 8270d to analyze them. I use DCM:Acetone (1:1) to extract PAHs from the sample. But sometimes, they create colors with this sample (such as pink...). I don't know whether they react together to create this color ???
Thanks !
Posted: Sun Jun 28, 2009 1:40 pm
by Kwet
I don't think that PAH's react together. PAH's colors ranged from yellow, amber to brown. Other colors should came from impurities in your sample. I remember to analyse some samples with pink extracts coming from waste sludges of a food industry.
Posted: Sun Jun 28, 2009 4:08 pm
by brightsun
I mean whether there are reaction between solvents with extracts ???
You are right, i'm extracting from waste sludges of a food industry.
What happened in this situation ???
Posted: Sun Jun 28, 2009 5:56 pm
by tom jupille
You probably have a lot of other compounds with fused aromatic rings. In general, the greater the number of conjugated double bonds, the lower the energy jumps (i.e., the longer the wavelength of light absorbed). At some point, the absorbance maximum creeps out into the visible, and you;re left with a pink color (the blue light is absorbed). Remember that your extraction is taking out *all* of the non-polars, not just the pnah's .
Posted: Thu Jul 02, 2009 5:22 pm
by AICMM
brightsun,
Food sludges? I would guess there are dye's being used to give the food a certain color?
Best regards.
