Ugly peak shape of amine compound
Posted: Tue Jun 09, 2009 1:30 pm
Dear all,
Let me state our current situation first:
We have only 1 C18 column in the LC-MS instrument. The only mobile phase we use is MeOH and H2O.
Usually C18 give us a good peak shape for simple/small molecules. However, some colleages give us compounds with mass > 1550 and with 2-3 amine groups in it. Also some guanine-like groups are attached.
This cpd give us a terrible peak shape at about RT 12min and I start to add 0.1% formic acid in H2O mobile phase. Hence, the peak is sharp and shift to injection peak region.
I am not sure if I am correct: By adding formic acid, we made the amine group protonated, hence the cpd become ionic and then no interaction with C18 column.
So, should I start to consider buying HILIC to run those amine protonated samples? Can I use MeOH in HILIC? And any other choice apart from HILIC?
Thanks in advance!
Thanks in advance!
