Matrix contamination of PAH analysis
Posted: Tue Jun 09, 2009 10:59 am
Hi all,
I am currently working on a method for PAH analysis of marine oil to be analysed by GC/MS.
Having searched through previous topics i can see that this field has arisen before with different techniques being proffered.
I am currently using the following method:
-Dissolve oil in hexane and mix with conc sulphuric acid
-Centrifuge contents and remove upper layer
-Run upper layer through supaleco dioxin column
-Concentrate sample down to almost dryness
-Re-suspend contents with 100ul toluene
However, i am experiencing poor recovery (<50%) and there is still quite a lot of noise on my traces from the oil matrix not being removed completely.
If anybody has any experience with this subject i would be grealty of any advice.
Steve
Steve
