Solvent adducts in ESI
Posted: Wed Oct 14, 2020 7:19 am
Hi everyone,
I am running ESI LC-MS on Shimadzu 2020 using ACN and H20 acidified with 0.1% FA, and was getting tall mass peaks at 101 and 142 m/z, which I found are (2ACN + H2O + H)+ and (3ACN + H2O + H)+, respectively. My concern however is that my presumably pure compound mass peak also comes as two peaks with a difference of 41 m/z.
I thought that changing solvent would prove whether this difference is from ACN, so I changed my solvent B to methanol (0.1% FA), and now I am getting two mass peaks of my compound, with a difference of 32 which is a loss of methanol.
Because I don't know what my purified compound is, I am wondering what would be the best approach to just get one mass peak, instead of two. Would increasing pH make any difference?
Thank you in advance!
(I wasn't sure if I should have posted this in sample prep or LC-MS)
