High speed centrifuge 50% ACN in H2O solution bad idea?
Posted: Fri Oct 09, 2020 9:12 pm
by chemist23
I have a sample extracted in 50% ACN in H2O and want to clean it up using high speed centrifuge (14,000 rpm).
Would centrifuging at this high speed alter the 50% ACN in H2O solution?
Re: High speed centrifuge 50% ACN in H2O solution bad idea?
Posted: Fri Oct 09, 2020 10:28 pm
by Consumer Products Guy
Weigh your centrifuge tube before and after, see if significant change.
I'd use tubes with caps.
Posted: Wed Oct 14, 2020 12:48 pm
by dblux_
Centrifuging won't alter solutions, but will alter suspensions and emulsions.
