Saccharin in water
Posted: Sat Oct 03, 2020 8:09 am
by hts123
Do anyone have any idea with how to extract saccharin from water samples using solid phase extraction? I had tried to acidify the water samples to pH 1 then passed through oasis hlb cartridges at 5mL per minute but I could not recover any saccharin! :|
I appreciate any help from any fellow forum users.
Thank you for reading! :)
Re: Saccharin in water
Posted: Sat Oct 03, 2020 1:48 pm
by Consumer Products Guy
Why is there need to extract the saccharine? With its structure, should have decent UV absorbance if you're just trying to quantitate the level.
Posted: Tue Oct 06, 2020 7:45 pm
by James_Ball
Have you tried it at a neutral pH?
I see it sometimes in wastewater samples done by sepfunnel extraction but have never done it by solid phase, though it should work.
Maybe try a plain C18 on silica cartridge also.
