The analyte is nitrilotriacetic acid. I am using CuNO3 to increase the sensitivity of the molecule as it chelates like EDTA. The stock of CuNO3 was 10mg/mL and we are trying to cut it down to 1mg/mL this morning which should be enough for our lower NTA limit. The problem I am having is accumulating back pressure and tailing of 2.3-2.7, lesser tailing at lower concentrations. Here are the method parameters:
Column = 4.6x150 mm NH2 (tried SAX but too strong)
IV=25µL
FR=0.5 ml/min
MP A = 5mM NaH2PO4 pH = 7
MP B = 5mM NaH2PO4/100mM Na2SO4 pH = 7
MP C = IPA (tried blending in MeCN 2, 5, 10, 15%, no difference noticed)
Column @ 25C (40C makes no difference)
Any suggestions?
