A difficult question REG Files...
Posted: Tue Jun 02, 2009 6:21 am
by uranyum238
Hi there. i made a reg file, you know reg files likes dll file in windows. i made it but i didnt run it. i dont know this. I try commands, loadObj but nothing. An idea??
Posted: Tue Jun 02, 2009 8:45 am
by aceto_81
export a key of your register to a reg file, take a look at this, then you know how to buildup a reg file.
HTH
Ace
Posted: Tue Jun 02, 2009 1:30 pm
by GasMan
Are you talking about ChemStation .reg files or Windows .reg files.
If you are talking about ChemStation files, how did you make the file. The ChemStation .reg files are basically data files that you would you use with a macro. If you type in LoadObj XXXXX, you will not see anything. You have just loaded the file into Chemstation.
Gasman
Posted: Wed Jun 03, 2009 7:36 am
by uranyum238
Yes, we are talking about Chemstation reg files. Ok i used loadobj command and i loaded my reg file, how can i run this.
Posted: Wed Jun 03, 2009 1:53 pm
by GasMan
You can not 'run' a ChemStation .reg file. It is a data file. You use a macro to access the data in your .reg file. Normally your macro should load the .reg file for you.
Gasman
Posted: Tue Jul 21, 2009 2:27 pm
by uranyum238
Thank you again GasMan. I did it.
