(LC/MS) m/z 282 is "plasticizer in polyethylene"?
Posted: Mon Jun 01, 2009 3:54 pm
by Anthony_Ng
Dear all,
Recently I run the LC-MS with +ve scan (ESI+APCI) and notice that there is a huge response m/z 282.
I searched related topic in this forum and found some hints (which was posted around 2004)
Is there any further method that I can confirm the m/z belonged to "plasticizer in polyethylene"?
I remebered one team member synthesized a compound with -SiMe3 in it. Would the peak belonged to silica related compound?
And...any web site have info about common LC/MSD contaminants?
Thanks in advance!
Posted: Mon Jun 01, 2009 6:30 pm
by bhuvfe
Anthony_Ng,
I guess you are referring to this http://en.wikipedia.org/wiki/Oleamide (slipping agent).
Did you use any plastic container with organic solvents?
Instead if you think you have a silicon atom you should see a different isotopic pattern.
Do you have access to a GC-MS? That would be a very easy way to confirm/exclude oleamide.
Regarding the list of common contaminats. The supplier of your MS should be able to help you.
bhuvfe
Posted: Wed Jun 03, 2009 2:11 am
by Anthony_Ng
Thanks!
Actually this mass shows everywhere even in basline.
Probably it comes from MeOH. When I switched to other brand, m/z 282 is small but another m/z 339 is very large.
We didn't use plastic ware but use a small glass vial for sample preparation.
