Dionex AS autosampler moduleware
Posted: Thu Sep 17, 2020 11:08 pm
by ljc
I need a pre-2.30 .fmw file to revive my AS autosampler. With the AS_2.30 moduleware, I get errors in CM6.8 such as "bad parameters" returned during a "wait" command. Can someone be kind enough to share one? The previous one was 2.20 and worked ok but since it wasnt broke, well, you know the rest...
Re: Dionex AS autosampler moduleware
Posted: Sun Sep 27, 2020 1:05 pm
by BostonFSE
Bad Param error means you’ve maxed out a variable count in the front screen panel. If I remember, I think it’s number of injections, reset to zero using the keypad and it will work again. No FW needed
Posted: Sat Sep 25, 2021 8:11 pm
by dangdk
Hi, did you ever get the firmware? We have the exact same problem as you and really need the firmware too! If you have a copy it would be great if you could email it to me at dj-hayes@hotmail.co.uk
