Stationary Phase for Sodium Alendronate EP Method
Posted: Wed May 27, 2009 12:51 pm
I wonder if any of you have compiled a list of comercial alternatives for Europen Pharmacopoeia stationary phase Anion exchange resin R1(1123400).
Our AD lab have to compare the results obtained with our "in house" HPLC methods for inorganic impurities and assay with the corresponding monograph methods (SODIUM ALENDRONATE-01/2008 :1564-corrected 6.3).
The monograph indicates that a Column l = 0.15 m, diam. = 4.6 mm filled with Anion exchange resin R1 (7 um) (Anion exchange resin R1. 1123400.: Resin containing quaternary ammonium groups [CH2N+(CH3)3] attached to a lattice consisting of methacrylate)have to be used for the assay and purity analysis of alendronate sodium.
The column indicated in the Pheur Knowledge Database is Allsep Anion Column: l = 0.15 m, diam. = 4.6 mm 7 µm from Alltech (Now merged into Grace Davison - Discovery Sciences).
We were having troubles obtaining that column as distributors informed that both Columns Part number AT 51208 (SS body) and AT 51209 (PEEK body) are out of stock and are going to be discontinued.
We contacted directly Grace Davison - Discovery Sciences.
Its Technical Support Manager Susan Diaz (Susan.Diaz@grace.com) informed us that:
QUOTE "I am sorry but both the Allsep column and Allsep A-2 column are either discontinued or in the process of being discontinued.
We do not have anything that would be an equivalent.I am sorry but we no longer have a column that meets the specifications that you have listed below."UNQUOTE
I can't find any packing that would be an equivalent to Anion exchange resin R1 (7 um).
Can anybody help finding an equivalent alternative?
Many Thanks!
Many Thanks!
