quadratic curves in chemstation
Posted: Tue May 26, 2009 10:09 am
A couple of questions:
From what I can gather, when you set chemstation to fit curves by quadratic regression through 0,0 the curve that is generated always takes the form:
Y = ax2 + bx
where y = response ratio; x = conc. ratio; a does not equal zero
This is a vertical parabola. For most analytes, response reaches a maximum at a certain concentration, so the parabola is an 'arch' (as opposed to a 'valley') and the quadratic term (ax2) is negative.
This means there is a maximum response, above which no result can be returned. Is this why chemstation sometimes returns a -2.00 result (which I presume is an error code)?
Also, there are two possible conc. ratios for a given response below the maximum. I presume chemstation always returns the lowest result?
I would have thought that a better curve would be:
x = ay2 + by
which would give a horizontal parabola peaking to the left (c-shaped). this curve would still have a maximum response but only one possible concentration for a given response.
I guess it's swings and roundabouts but is there a way to choose which parabolic function is used? I thought maybe chemstation would select the most appropriate but I entered in data that would give a perfect horizontal parabola it chose the vertical parabola.
Y = ax2 + bx
x = ay2 + by
