GCMS- TIC problem
Posted: Fri May 22, 2009 6:43 am
I am using Thermo PolarisQ GCMS. I am working in pesticide analysis in food products. the standard i am using is a mixture of 15 compounds. But the TIC of the analysis shows almost no peaks in it. But when i search the compounds ushing their base peak then i can identify the compounds one bye one. Can anyone suggest me to get the TIC for all the 15 compounds at a time?
Thank You
Seeni
Thank You
Seeni
