Peak Area Keeps Changing
Posted: Sat Aug 22, 2020 10:59 am
I am running an analysis for a sample DCVC Anhydride and all I need is a consistent set of injections with regard to peak area for it to pass. In my run there is one impurity. This wouldn't be a problem except that the peak area keeps fluctuating between it and the DCVC Anhydride area.
It went from 68:32, 70:30, 72:28. The injections should be within 1% for a pass result. The diluent is ethyl acetate. Injection volume is 1.5ul in a 5ul syringe.
There were other Standards that I ran with the same method and column that passed easily.
Why is it failing only for this one? I'm thinking injection volume is too high.
