Unexplained peaks
Posted: Fri Nov 19, 2004 9:47 am
I am fairly new to HPLC. I am using a brownlee aquapore column and guard column with C4 packing. I am using it to analyse wine proteins with buffers:
A: 10% ACN / 90% Milli Q water / 0.1% TFA
B: 90% Milli Q water / 10% ACN / 0.1% TFA
I am using this in an agilent 1100 machine and detecting peaks at 220 nm.
The gradient runs from 0 to 60% B over a period of 20 minutes (the gradient varies over this period).
I was getting some weird peaks coming off at about 12 minutes so I tried runnning some milli Q water samples and got the same peaks. I also tried running blanks and got the same peaks.
I have made up new buffers but that hasn't fixed things. I used a new bottle of ACN. We are right at the bottom of the bottle of TFA and we didn't have any more so I used TFA from the same bottle.
I cleaned the column with 100% B for an hour and when this didn't work I replaced the guard column and then the actual column when this didn't work either.
I don't know why we are suddenly having problems. I ran 100 similar very samples just 2 days earlier and had no problems.
Would greatly appreciate any help.
Cheers,
Laudrup
Cheers,
Laudrup
