In your subject line you write about sending data files, in your text you write about results.
If you are trying to send data files, it sounds like you are trying to network a couple of PCs together.
then you need to create a null modem network cable
http://www.lammertbies.nl/comm/info/RS- ... modem.html
http://www.taltech.com/TALtech_web/reso ... ro-sc.html
and then have software running on data acquisition PC to act as a server to send to the receiving PC that will be acting as the client.
you can program chemstation macro to signal the serve programme (eg by DDE) which directory to send automatically via the rs232.
I would strongly recommend getting an old Ethernet card and creating a LAN, that way you can use the windows explore software, and there is no issue of potentially corrupting your data via transmission.
If you are trying to send results, eg a name plus a concentration, then you can program chemstation to signal to the server program those results to send down the RS232.
Chemstation does not have any built in functionality to talk to comm ports directly, which is why you need the server software
If you want to know where to get the software, then you can write it yourself, or try and find one off the internet.
regards
Alex
