Supressing Cl ions from evaporating in HF
Posted: Fri May 15, 2009 2:07 am
i am trying to quantify trace Cl in HF acid using an Ion Chromatography system. However when doing a recovery, i find that all the Cl ions is lost when i evaporated the HF acid.
Does anyone know of any chemical which i can add to prevent the loss of Cl ions while still eliminating the F ions which upset the accuracy of the chromatogram?
