Removing a Thermo Trace inlet adapter.
Posted: Tue Jul 21, 2020 11:43 pm
Hey all. I've decided to remove the capillary inlet adapter from my Thermo Trace GC Ultra's S/SL inlet. It's the sort at the following link, which slides up into the inlet and gets compressed on with a nut and a silver sealing ring (https://blog.restek.com/wp-content/uplo ... oinlet.jpg). Does anyone have any tips on how to get the thing off?
It is ON there good, probably through a combination of buildup around the giant surface area overlap with the inlet, and the seal itself. This thing has been there for a truly irresponsible amount of time without being swapped. I don't want to reef on it with a pair of pliers, as I don't want to risk deforming the end of the inlet. I don't want to try to jam a screwdriver into/under the silver seal, as I don't want to risk damaging the sealing surface. And I'm worried about what might actually give if I stick some sort of tool/rod down the inlet and hammer on the top of it with a mallet.
Anyone got any hints or tips?
