GC-FID won't power on
Posted: Fri Jul 10, 2020 3:20 pm
Agilent 6850 GC, about 15 years old. Powered on the GC after lockdown was lifted, it powered on briefly then went off, cycled the power again and same thing happened then wouldn't power on again.
I tested all four fuses on the AC board and all three fuses on the main board and they were fine. The fan in the back of the GC (connected to the main board) still spins, but the lights on the LAN card aren't lighting up. I don't see any other lights on the boards, but not sure if there should be any. I do have a second GC of the same model so I could switch parts to try and figure out what needs to be replaced, but was looking for any insight as to what I should be looking at first, and whether there was any risk I could damage the second set of parts by doing so...
Thanks!
Thanks!
