Is there a way to do math in Chemstation A.10.02 tables?
Posted: Fri Jul 03, 2020 11:44 pm
by osp001
Customer wants us to report peaks in combined format, i.e.: Column A plus 65% of Column B, but not Column C nor D. Looks like it's easy enough to go into the footer of a table and do @sum and get the *sum* of all four, but is there any way to create formulas and pick-and-choose different data points in this version of Chemstation?
Re: Is there a way to do math in Chemstation A.10.02 tables?
Posted: Wed Aug 12, 2020 3:01 pm
by LALman
You probably need the appropriate version of Excel and you can edit your report table. But if you use too new a version of Excel; it will corrupt the table.
I export my data via that table by calling as a link in a newer excel sheet. I do all my post calculations there by linking to the xls sheet produced by chemstation.
