Choice of volatile buffer and mobile phase in HPLC-MS
Posted: Tue Nov 16, 2004 4:56 pm
I understand that to get the best MS sensitivity you should use in RP-HPLC-MS for basic drugs (I guess most people would use ES for this).
a) A high concentration of organic solvent- I think this helps the spray conditions.
b) formic acid rather than TFA. I think TFA gives ion supression due to ion pair effects with the protonated bases. Are there also other problems with TFA? The manufacturers of some systems seem to suggest that once used, it will remain in the MS for ever! Any comments on these points?
If I want to use formic acid at a higher pH to obtain a different selectivity in my separation, I could adjust the pH with ammonia-still volatile! Assuming my drugs are very basic and this does not affect their protonation state, how will the presence of ammonium formate affect the MS sensitivity? Has anyone done this?
I guess the same things apply if anyone has experience of this question in peptide analysis.
Many thanks for your help
