GC FID temp not installed
Posted: Sat Jun 13, 2020 4:12 pm
When I was doing the experiment. Suddenly, The thermal system had a fault. Then, the warning alarm rang. All the temperature was off. So I waited for everything cooled down. Shutdown the GC system completely. After that, I restarted the GC. I increased the FID’s temperature to 200C. Everything was good. As I increasing the temperature to 400C. FID’s temperature cannot stable at 400C. There was much oscillation here. Then, the front panel of FID showed “ Temp not installed”. Is that mean some units were broken down? Do I need to replace some sensors?
There was a similar problem is posted in the forum. I don't whether the problem was solved. Here I put the link. Thank you all the people who can reply to this post
https://chromforum.org/viewtopic.php?t=25467
