Multiple Headspace extraction using Agilent 7697A
Posted: Fri Jun 05, 2020 9:39 pm
Hope everyone are keeping well in these strange times.
I am trying to develop a multiple headspace extraction method to measure caffeine in solids such as ground coffee.
Is there anyone out there doing MHE on an Agilent 7697A system as I would welcome any advice as to possible settings as part of the headspace parameters.
So far on one occasion I ran 5 extractions from a caffeine standard and got the expected results with the peak area of the caffeine decreasing according to the predicted Ln relationship. Since then I have run into problems and can't get things to work even when using the same conditions
Typically if I do 5 extractions from the same vial I only get peaks on the 5th run. If I do 3 extractions from the same vial I only get peaks on the 3rd run etc.
I have tried changing some of the settings in the headspace parameters such as the flow settings but without success partly as I am not totally sure of what each parameter does. I have spoken to Agilent but as this is quite an uncommon way of doing things they aren't too familiar with what I am trying to do.
Anyone able to help with some suggestions
Kevin
Kevin
