Failure to Configure Corona CAD with OpenLab Chemstation
Posted: Fri Jun 05, 2020 4:02 pm
by Vlad Orlovsky
I am looking for help with integrating Corona with Agilent 1100. I have OpenLab Chemstation (C.01.10) and an older version of Corona (part number 70-6186A). I would like to integrate it with Agilent using USB A to B cable. I spoke with Agilent and Thermo several times and they cannot help me. The driver I purchased from Thermo gives an error of "catastrophic failure" when attempted to install. I know that I can connect it through Agilent A/D converter (35900E), but would like to do it through direct connection to the computer. After spending couple of days on this I am not sure that Thermo has drivers which support this old Corona in combination with Windows 10. The most annoying issue is that each of the companies says that it is not their problem.
Any advice is greatly appreciated.
Re: Failure to Configure Corona CAD with OpenLab Chemstation
Posted: Tue Nov 03, 2020 6:46 pm
by LCwatcherGE
Dear Vlad,
for the Corona CAD there was the driver from ESA Biosciences, Inc., which was written for Windows XP, compatible with ChemStation B.02.01 and higher.
For the (OpenLab) Chemstation C.xx.yy only drivers for the current Corona Veo/VeoRS are available, not for Corona CAD.
