Negative Base line in PDA
Posted: Wed Apr 29, 2009 4:04 pm
Hi all ,
a vey good evening
We are facing a strange problem with PDA Water's alliance system .
We developed a method on Zorbax-C18 column with following parameters.
M.P-A-93:7:0.1 (Water:ACN:TFA)
M.P-A-13:87:0.1 (Water:ACN:TFA)
flow-0.4 mL/min Wavelength-265 nm Column Temp-25 C
Gradient(Time/%B)-- 0/10, 5/10, 20/50, 45/85, 50/90, 60/90, 62/10,70/10
We found a negative drift at exactly rt of active.This is found in PDA systems ,not in DAD systems.We r digging our heads to find out the cause for this.Please help us.
