HPLC, help:)
Posted: Mon May 25, 2020 1:47 am
Okay so HPLC is not my strongest subject and I'm baffled hopefully il be able to find some help.
A sample was analysed on an HPLC equipped with a 15cm long column with an internal diameter of 4.6mm and a flow rate of 1ml min-1. the column was packed for 65% with a C18 stationary phase. An unknown peak appears at 0.87 min. Determine the likelihood that this peak has any interaction with the solid phase, show all working out
This is the question I was given, I tried googling but I can't seem to find anything, maybe I'm not googling the right thing, any help would be much appreciated
thanks in advance
thanks in advance
