HPLC Agilent Maintenance
Posted: Mon May 11, 2020 2:33 am
Hey,
Can someone answer me to few simple (for experienced HPLC Agilent users) questions consider HPLC maintenance because I'm confused with Agilent manual. And I want to do exactly perfect, proper way
1) How to properly prime degasser in pump mode? I mean I read in manual of Agilent Micro Vacuum Degasser 1100 that I should flush degasser with at least 5 ml of water however in Agilent HPLC Maintenance and Troubleshooting I read that I should use isopropanol and in Agilent Pump Manual they recommend flush with 30 ml of, again, water. Some different, other source recommend use just solvent. What is the best? There is some difference in flow rate in flushing degasser and priming the pump?
2) When I use phosphate buffer (0.03 M) how should I clean all capillaries in HPLC system? Again, once they recommend to pump water or isopropanol? If isopropanol what is the ratio for isopropanol:water solution. What i s better? And what is the time period for that? Like 2-3 hours? Or overnight?
3) What is the best way to clean column? If I used for mobile phase ACN:Water should I use only Acetonitrile?
4) How often do you change purge valve frit?
Thank you in advance
