Custom Field Calculation
Posted: Mon May 04, 2020 7:42 pm
I'm having trouble creating a custom field in empower I hope you can help me.
So, there was a post similar to my question a long time ago here on the forum - https://www.chromforum.org/viewtopic.php?t=17231
It has very useful information that almost solved my problem
What I want is:
A field that averages multiple injections with the same label.
Vial --- Inj --- Label
1 ------- 1 ------ A
1 -------- 2 ------ A
This should be resolved with the following field
Search order: Results Set only
Sample Type: Unknow only
Peak Type: Found only
Formula: SAME⦠AVE (Amount)
But it does not work
Then I tried the following formulas:
- SAME.% .. AVE (Amount)
-.% .. AVE (Amount) (this does not specify the label but served as a test)
None worked
But when I change the Search order to Outside Only the formula works perfectly, but it is using previously processed results with the same label in the same project, which is not what I want
I wanted the average of the injections done in the current processing
What am i doing wrong ?
What I want is:
None worked
