However, the good news is that when using a JetDirect 400N smart card and configuring the software to use an IP address, I have yet to discover any issues. Luckily the card defaulted to an IP address of 192.0.0.192 and I did not have to use a bootp server. I don't have a G1369 LAN card to test otherwise I would have. I have installed Chemstation as an administrator and used the option "run as administrator" for the desktop shortcut. I also allowed Chemmain.exe through the Windows firewall. I also run the program in compatibility mode for Windows 7. Just wanted to give people some good news with Windows 10 and B.04.03.
