Does column i.d. affect back pressure?
Posted: Fri Apr 17, 2009 3:10 pm
Hello all,
I know that the longer the column, the higher the back pressure will be for the same particle size.
If I keep the particle size and column length no change, what is the pressure change with different i.d. size?
Thanks in advance.
Thanks in advance.
