Standby GC-ECD / MS
Posted: Tue Apr 28, 2020 3:43 pm
I use Agilent GC ECD/MS and I want to put my GC into "standby/sleep" mode during night... I thing that ex-collegue put oven off, inlet off and also front detector (ECD) off, but make-up si on - manually with keyboard. I think that make up gas is on and also pressure on column. What is the best way to achieve "save gases-sleep mode" without GC damage?
I think that when GC-MSD is used, Aux is always on, oven, inlet - off.
Should column have always set flow through column? What kind of flow settings would you recommend me to use to save as much gas as possible?
How long then stabilization lasts?
Thank you
Thank you
