USP 467 Class 2 mixture C missing from procedure?
Posted: Mon Apr 27, 2020 10:41 pm
by chemist23
Is there a reason why the preparation for Class 2 mixture C is not included in the procedure? I am wondering if this standard is necessary for residual solvents analysis as per USP <467>?
Re: USP 467 Class 2 mixture C missing from procedure?
Posted: Tue Apr 28, 2020 2:38 pm
by AndyA
I don't know why it isn't a part of <467>.
if your testing as per <467> following procedure A and then B. You only should need the class 1 mixture and the class 2 mixtures A and B.
Posted: Tue May 12, 2020 7:22 am
by Humphrey77
a cumulative procedure may be used to calculate the residual solvent levels in the ... Residual Solvents Class 2—Mixture C RS to a 100-mL volumetric flask, dilute ... tellpopeyes caused by a substance and that disappear after exposure to the substance.
