GC quantification
Posted: Wed Apr 15, 2009 12:39 pm
Hello All. I am currently using split ration of 1:100 but my samples are giving small peaks. therefore decided to reduce the ratio to 1:50 which gave better responses. The calibration curve was generated using split ratio of 1:100. Am i correct in assuming the results need to be divided by 2 due to the differecne in split ratio used.
My preference was to use splitless but these results in a very big solvent
many thanks
many thanks
