Able to connect to Agilent 1100 DAD but not other modules
Posted: Fri Apr 17, 2020 8:42 pm
Starting another thread on this issue since the problem has changed.
I am able to get ChemStation to recognize the DAD on an Agilent 1100, but the other modules are not appearing as "online". I get good ping between the computer and the DAD; the instrument was purchased secondhand (serviced, working, tested- sat for two years in a box), and does not appear to come with Lab Advisor. Anyone know if the Lab Advisor for download from Agilent will work? Or is this just a firmware update?
https://www.agilent.com/en-us/firmwareD ... whid=69761
Anyway- I've tried regular Ethernet cables to connect the modules, made some crossover cables and tried those, then bought some "Agilent 1100 CAN" cables from eBay, and none of them work. I've tried skipping over the thermostat module to the autosampler module, no joy. I've tried using both of the CAN ports on the DAD module without success.
Anything else I should try?
