What is the Optimum strength for phosphate buffer
Posted: Sat Apr 11, 2009 6:13 am
by shantaram
Up to how much strength of potassium dihydrogen phosphate(pH5.5), i can go in HPLC and please tell me how should i wash the column after every batch run...
Posted: Sat Apr 11, 2009 11:50 pm
by tom jupille
That depends on the identity and concentration of the organic solvent (which will affect the solubility of phosphate). For use with UV detection, levels of 10 - 50 mM are common; 100 mM is not unheard of. These are values in the aqueous portion of the mobile phase (i.e., before you add organic). It is a good idea to check for buffer precipitation problems "off-line" in a test tube before trying it on the HPLC system.
Hopefully, you are also aware that pH 5.5 is well outside the buffering range of phosphate.
Posted: Mon Apr 13, 2009 7:42 pm
by LC_labrat
As for washing the column take a look at this article on column care.
http://chromatographyonline.findanalyti ... oryId=9678
Posted: Wed Apr 15, 2009 5:06 am
by shantaram
Thankyou. as far as buffer range of phosphate buffer is concerned i am aware of that, but i had tried different pH soluyions but the best response and separation is coming on that pH only. could you please explain how it can affect my analysis...
Posted: Wed Apr 15, 2009 5:54 am
by shantaram
Thankyou for that link that was really informative
Posted: Thu Apr 16, 2009 2:54 am
by tom jupille
If your results are sensitive to pH, then I would be very concerned about phosphate at pH 5.5 .
In order to control pH, a buffer must be able to both donate and accept protons. That ability is maximum at the pKa of the buffer (the pH at which it is effectively 50% ionized). pH is a logarithmic function; I won't go into the math, but +/- 1 pH unit from the pKa and the molecule is either 90% or 10% ionized; +/- 2 pH units from the pKa and the molecule is either 99% or 1% ionized - which means that it can either donate or accept protons, but not both. The working range of a buffer is generally given as +/- 1 pH unit. Phosphate has pKa values of about 2 and 7. A better choice for pH 5.5 would be acetate (pKa 4.7).
If your separation is not very sensitive to pH, then it may not matter.
Posted: Fri Apr 17, 2009 10:30 am
by shantaram
Thank you, i will switch over to ammonium acetate as i had tried it....and also phosphate buffer may be the cause of fluctuation occurring in the analysis...
