Looking for a universal PDF chromatogram generator
Posted: Tue Apr 14, 2020 4:13 pm
by Simon Wicks
I'm exploring the possibility of off the shelf software solutions for my lab. We currently use Perkin Elmer, Shimadzu and Agilent FID systems. They all use dual column, dual detector arrangements to produce two chromatograms from one injection. Currently we have a bespoke set of programs and macros that generate a pdf to our spec - basically landscape view, both chromatogram channels displayed one above the other with area % displayed on each peak. It runs each time a sample finishes. Another program then uploads it to our bespoke LIMS system. It works for the Perkin Elmer and Agilent softwares but not Shimadzu.
I am looking to see if there is anything that can do this that is an off the shelf setup and can preferably work with the Shimdazu software aswell. The program is notoriously complex to troubleshoot requiring more programming knowledge than we'd like for front end analytical chemists. I can set instruments up, fix them etc.. but writing programs is beyond my knowledge. The guy who made the software may not support it much longer either leaving us in the lurch. We either hire another software engineer to pickup where he left off or get an off the shelf solution. The latter is likely more expensive but support is going to be more readily available around the world.
I've had a look at Chromperfect, which seems interesting. I've heard Empower may do this aswell. Has anyone encountered anything else?
Re: Looking for a universal PDF chromatogram generator
Posted: Tue Apr 21, 2020 1:07 pm
by larkl
You might take a look at ThermoFisher's Chromeleon. You can do dual channel acquisition and reporting. Might take some tweaking to get the data into your LIMS.
Posted: Tue Apr 21, 2020 9:49 pm
by James_Ball
Have you looked at Agilent's OpenLab? It lists compatibility with Agilent, PE, and Shimadzu. I guess depending on the age of the instrument would be the only limit on compatibility.
https://www.agilent.com/en/products/sof ... ifications
Posted: Thu Apr 23, 2020 6:57 am
by antonk
Our UniChrom recently got the ability of internal PDF report generation using fcl-pdf library. In a couple of days we'll upload distribution here:
https://www.unichrom.com/chrom/ucdle.php
* UniChrom reads Agilent .ch, Perkin-Elmer .raw, Thermo .raw, Shimadzu .gcd
Full list of formats supported https://www.unichrom.com/chrom/uc-ffe.shtml
* Data processing and report generation is free
Output example
https://www.unichrom.com/pdf-gen/output1.pdf
Report-generator screenshot
Posted: Wed Apr 29, 2020 3:53 pm
by LALman
So, you are not actually looking for, you are selling.
